8/31/2016 1:50 PM | |
Posts: 5225 Rating:
Hi. Thank you, I understand your situation better now. It seems as though you are faced with a synchronization problem. There is an article about something like that (I did not work through it yet).... I would have 5 sets of data if I designed this.. Coding is then needed to evaluate changes made and decide how to make all equal again. If you take it a step further, (c) and (d) only carry values that needs to be synchronised. Not handle a block of data, only that what needs changing. Very much the same idea as Modbus already does. So what specifically can the Forum help you with? |
