12/16/2018 8:24 PM | |
Joined: 10/12/2009 Last visit: 9/29/2023 Posts: 23 Rating:
Hello CaOd, thanks for your reply, please can you look attached file and can you check following links when I checked following links there is no process automation or chemical industry in the S7-1500 link. s7-300 link; https://w3.siemens.com/mcms/programmable-logic-controller/en/advanced-controller/s7-300/cpu/pages/default.aspx#Range_20of_20application S7-1500 link; https://mall.industry.siemens.com/mall/en/ww/catalog/products/10204162?activeTab=order®ionUrl=WW#Application |
8/6/2020 8:29 AM | |
Posts: 59 Rating:
Might be, just my 2 cents, the list is made up prior to Redundant System of 1500 (R/H). And as far as I assume, the S7 1500 not suite for Chemical and Petrochemical is because they don't compliant within G3 coating requirement. Siemens Normal modules as per attachement showing all S7-300, S7-400, ET200M, ET200S, and ET200iSP modules are approved for implentation with high concentration of corrossive gas in compliance with ISA-S71.04 severity level G1;G2;G3. AttachmentISA compliance.pdf (128 Downloads) |
