9/15/2022 4:32 AM | |
Joined: 1/21/2013 Last visit: 9/29/2023 Posts: 2084 Rating:
Hi hossamhegab, for selecting the hardware, I would recommend the TIA Selection Tool. This software is free for use and available as cloud version and as standalone version for Windows 10. In both versions, you can use the plant configuration to get a hardware selection for your requirements. Kind regards |
9/15/2022 8:01 AM | |
Hi hossamhegab, the choice of the PLC does not depend on the amount of I/Os. For this, the required performance and the required memory would be important. It might also be important to know, if integrated safety or enhanced technology functions would be required. In the current situation, the delivery time may also be a decisive factor for the choice of hardware. If you think about the use of the decentralized periphery, for in-cabinet use, I would recommend the SIMATIC ET 200SP. For periphery outside the cabinet, the SIMATIC ET 200AL. For further advice, I recommend contacting the Siemens Technical Consulting. You can use the contact database to find the contact details for your location. Kind regards |
9/24/2022 6:48 PM | |
Joined: 12/4/2018 Last visit: 5/31/2023 Posts: 23 Rating:
Thanks for all, I found this documentation very helpful and now I can select the system easily.
Attachments7-1500_in_a_nutshell.pdf (227 Downloads) |
