7/13/2019 7:04 PM | |
Joined: 11/9/2016 Last visit: 2/28/2025 Posts: 2 Rating:
hi I am trying to get all available data from an E&H flowmeter model H100 via Profinet. thank a lot. |
7/13/2019 9:46 PM | |
Joined: 9/27/2006 Last visit: 3/26/2025 Posts: 12344 Rating:
Hello Thai PLC; The following document from E+H will give you most of the needed information in ch. 9, 10 and 11: E+H Promag H 100 Profinet manual: https://portal.endress.com/wa001/dla/5001030/7115/000/00/BA01421DEN_0115.pdf You will also need the GSD file (Profinet) for the Promag H 100, which you can locte starting with this link: Link for E+H downloads/Profinet: (GSDML file) https://www.endress.com/en/search?filter.text=gsd At the bottom of the results page you will find a Downloads button, which will bring you to a selection of downloads page: select DD (device driver), Type GSD, bypass the Product Code line and go to Text Search, write "Promag H 100" This will give you access to the GSD file;. Download the zip file available;see the attachment below. Depending on your experience with Profinet on a S7-1500 (Step 7 TIA Portal), the following video could provide a guide to configuring a Profinet IO connection to a IO device such as your flowmeter simply substitute the CPU in this example with your own S7-1500, integrate the GSD file mentioned above, Provide your flowmeter with a Profinet address and a "name" (any word could work, such as "flownmeter1"), select the modules you will use to exchange data between the flowmeter and the CPU, use the I/O addressing provided to connect the data in the CPU. https://www.youtube.com/watch?v=iTatmV0yw5c Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 07/13/2019 23:23:25Last edited by: dchartier at: 07/14/2019 00:52:50Last edited by: Jen_Moderator at: 07/15/2019 07:58:51Embedded video. |
7/14/2019 5:44 PM | |
thank a lot. |
