11/7/2024 7:45 PM | |
Joined: 7/19/2022 Last visit: 1/17/2025 Posts: 433 Rating: (71) |
Hello desertburner, I recommend you check that your display has the latest firmware version available and if not, try loading it to see if this solves the problem: Firmware update S7-1500 CPUs incl. Displays and ET 200 CPUs (ET 200SP, ET 200pro) If not, I attach how to proceed with the display change: Replacing the display/front cover |
