6/12/2017 8:10 AM | |
Posts: 3 Rating:
Hello All. I am using PLC 1511-1 PN (6ES7 511-1AK01-0AB0) and CM PtP RS 422/485 HF (6ES7 541-1AB00-0AB0). My communication is done. Here I use Modbus Master block and I got success to write data on slave AttachmentCM.zip (293 Downloads) |
6/12/2017 2:32 PM | |
Posts: 3 Rating:
Hello, Thank you for your reply. As you can see in attachment status is 7002 (Data Transmission running). In MB sim I configure 9600 baud rate with even parity as a slave. I use ADAM (Isolated Converter) with MOXA for converting RS-485 to RS232. AttachmentCM-1.zip (238 Downloads) |
4/10/2018 10:48 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
New question published by tiasarath is split to a separate thread with the subject Communication through CM PtP module - No data is coming and showing error code 16#7002. . Best regards |
