4/14/2018 11:51 PM | |
Posts: 110 Rating:
Hi, I would like to select best suitable distributed IO product from siemens. Attached the architecture and I would like to know If ET200S or ET200m will be cost effective. Looking for some good advice Regards Sandeep AttachmentSystem Architecture.pdf (222 Downloads) |
4/16/2018 5:24 AM | |
Posts: 110 Rating:
Hi, Thanks for the advice, I used TIA selection tool for ET200SP station but while adding more DO or AI module its showing load exceeding error |
4/16/2018 8:06 AM | |
Posts: 110 Rating:
Hi Christopher, I am not able to add power supply module to ET200SP could you please check the configuration file NOTE:- File EXTENSION CHANGED TO DOC FROM TIA FOR UPLOADING Thanks Sandeep AttachmentS71500.doc (112 Downloads) |
4/16/2018 10:06 AM | |
Posts: 110 Rating:
Hi, Thanks It worked and I have selected s71500 to ET200sp 6nos of Remote stations.. Regards Sandeep |
