7/14/2019 11:30 AM | |
Joined: 5/12/2012 Last visit: 12/1/2022 Posts: 28 Rating:
Hello everyone, I found a problem when using the library LCamHdl of the S7-1500T CPU, as shown in the figure. The curve generated online is a smooth position curve, but there is a slight overshoot in the actual running process. I don't know how to solve this problem. Please help us to see, thank you! AttachmentLcamHdl Test.pptx (82 Downloads) |
7/15/2019 4:19 PM | |
Dear, I configured the axis to activate the simulation. The test is to use plcsim advanced under several parameters, the running curve is the test in PPT. This is not the case with virtual axes. Is the simulation axis mode mimicking the real axis? The error caused by this situation does not know what will happen under real circumstances, and the gain is very large. Thank U for your help。 Attachmentnew.pptx (64 Downloads) |
7/17/2019 10:31 AM | |
Thank You for you help,Now i understand this 。 |
