3/9/2010 7:59 AM | |
Posts: 2930 Rating: (432)
Hi, what kind of information did you find and read concerning data logging? Runthe Data log wizard in STEP7 MW and lots of your question will be answered. Some answers you can find in the online help of the S7-200 Explorer The data will be stored on an EEPROM of the memory card. EEPROM has 100.000 write cycles. So if you record each second than tha card may be demadged after 100.000 seconds. The interval to write the data depends on you. How many memory left: You can find running the wizard and read the notes What happends if the data log record isfull and you go no recording: Run the wizard and read the notes. The data will be stored in CSV format on the card. Here an example: The daqte & time was not set in this test. I hope this helps Attachment(2) - DAT-Konfiguration 0 (DAT0) - 28.10.2009 10-16.zip (329 Downloads) |
3/9/2010 10:47 AM | |
Posts: 13 Rating: (0) |
Hi Thanks for the help. Currently i do not have access to microwin. My apologies for not doing enough my homework. Appreaciate your kind gesture. Regards |
