6/22/2012 12:10 PM | |
Posts: 20 Rating: (0) |
Hi I have attached a sample program I have tested this program as in n/w-1 &vb200 and &vb220 addresses are used when I0.0 is turned on then value 134217928 is moved in AC1 and value 134217948 is moved in AC2 I want to know what this actually means and from where this value is fetched from. Regards. Attachmentindirect_address_prog.zip (233 Downloads) |
6/22/2012 12:29 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715)
Hello, Attached part of the microwin help tells you more about this. Regards, Marcjan AttachmentPrinting _Direct and Indirect Addressing.pdf (405 Downloads) |
Problem solved? |
6/27/2012 4:46 AM | |
Joined: 11/30/2007 Last visit: 7/30/2024 Posts: 23 Rating: (0) |
Hi Just clear values in VB200 and VB220 by downloading Data Block or from status chart just trigger 0. |
