2/18/2014 5:38 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, There is a Converter Tool It is made for TIA V11, so it might not work with V12. If you have plain logic without using wizard and/or protected blocks it might save you some time. Attached you find more information about this tool. Regards, Marcjan Attachments71200_converter_tool_en-US.pdf (159 Downloads) |
Problem solved? |
2 thankful Users |
2/19/2014 12:59 PM | |
Hello, Found another link with newer version ,it supports TIAV11 SP2 and and higher ,tested the file, works with V11 here. Click Regards, Marcjan Attachments71200_converter_tool_en-US.pdf (98 Downloads) |
2/9/2015 10:32 AM | |
Posts: 79 Rating:
Is there a newer version of this program for TIA V13? This one here doesn't support TIA 13. |
