10/8/2021 6:07 PM | |
Joined: 1/31/2019 Last visit: 9/28/2022 Posts: 16 Rating:
Hi, Do you know if it's possible to connect a S7-200 with PPI communication with IOT2050? I found the following node for NodeRed but can I access to the PLC with the serial port of the IOT? https://flows.nodered.org/node/node-red-contrib-mpi-s7 Or maybe it's better to use a PPI adapter like below...? https://www.hilscher.com/products/product-groups/gateways/for-direct-mounting-plug/nl-50-mpi/ |
