2/17/2010 5:39 AM | |
Joined: 3/21/2006 Last visit: 12/4/2023 Posts: 10222 Rating:
Hello, Look at What should you watch out for when configuring a CP342-5 as DP master? And then give more details about your settings. It will be useful to attach here your project. Bets regards, Hristo Mihalev |
2/19/2010 12:05 AM | |
Posts: 3 Rating:
Hi, thanks for helping me with this problem. I' ve checked the link and I found it very usefull, but I'm stil having problems with the configuration. By the way, the especific hardware devices are: -CPU 313C-2DP 313-6CF03-0AB0 V2.6 -CPU 314 6ES7 314-1AF10-0AB0 /V2.0 with CP 342-5 6GK7 342-5DA02-0XE0 / V5.0 It doesn't matter wich works as "master" and wich as "slave". I hope you can help me, thanks. |
