11/28/2014 2:37 PM | |
Joined: 12/16/2012 Last visit: 9/11/2023 Posts: 646 Rating:
Hi John! I do not know the exact reason of your problem. According to the manual, after power on the data is available after the first conversion. Do you have a lot of analog input channels? If it happens only during the first cycle, you could disable your alarms for the first cycle using a First Scan bit.
Attachmentinfluence of the supply voltage ....pdf (39 Downloads) |
