9/5/2012 11:21 AM | |
Posts: 26 Rating:
Hi all, I have a CPU 315 which i have conected a MSS safety relay (3RK3 111). Using the example FB (https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=40631654&caller=view) i have being able to read the data from the safety relay. The thing i dont understand is that in the MSS configuration you can set outputs (SLOT 2 DP_OUT0.0 for example), where abouts are these bits addressed in the S7 configuration. I have attached a picture of my MSS configuration showing the availabe DP addresses Thanks Jon |
9/5/2012 5:15 PM | |
Posts: 26 Rating:
Thanks LesPaul, I wasnt sure if that was the addresses or not, i dont have one i can try at the moment! Thank you. Jon |
