3/25/2014 5:55 AM | |
Posts: 1 Rating:
Hi, I want to use do the H/W and S/W programming for implementing the CP CP communication between S7 300 and S7 400 as shown in attached document. So which blocks are required and who ( S7 300 or S7 400) should be defined as master? Is there any sample program for implementing ? I am a newbie in CP communication so if a detailed procedure for implementing will be shared it will help me a lot. Thanks in advance. AttachmentQuery.pdf (84 Downloads) |
3/27/2014 9:48 AM | |
Joined: 3/20/2013 Last visit: 3/24/2025 Posts: 676 Rating:
as dirk_ said: have a look in the compendium. there you can easily navigate to the communication you want (300 CP -> 400 CPU). afterwards you can search for documentation regarding the implementation. some more hints: FAQ for establishing an S7 connection http://support.automation.siemens.com/WW/view/en/17369594 FAQ for programming PUT/GET http://support.automation.siemens.com/WW/view/en/18610307 keep in mind: you can also use other functions/protocols depending on your requirements. |
Best Regards, |
