7/30/2008 2:03 PM | |
Posts: 62 Rating:
Last edited by: B_Moderator at: 8/4/2008 6:58 PMLast edited by: B_Moderator at: 04.08.2008 18:52after splitting |
7/30/2008 6:47 PM | |
Posts: 5822 Rating:
Hello, may you post what type of errors you get and where? Maybe you add also what type of CPU you use... and the order # of it. Best regards J_Bell |
8/7/2008 3:16 PM | |
Posts: 5822 Rating:
Hello, just as an idea... have you read theTips and Tricks chapter (8 I think)in the Manual in the Application: Sending and Receiving SMS Messages with S7-300/400 via serial CPs (340/341/441-2) and the GPRS/GSM Modem MD720-3 There you get an idea and with some investigation a tool to check if both, the CP and the Modem talk to each other. (Some even with both sides of the Communication in two separate Windows) I think it is worth a try. Best regards J_Bell |
