4/27/2012 11:54 AM | |
Joined: 4/19/2008 Last visit: 9/13/2023 Posts: 1525 Rating:
Hello Shahide043, If All the LED is Flashing Means there is a problem with CPU, CPU is Faulty, If it is under Warranty then Please Contact your Local Siemens with Serial No. (Normally you will find after MLFB no. Starting with S VPXXXXXXXXX) Or Contact Support Request... |
Ammy |
4/27/2012 12:04 PM | |
Joined: 3/18/2008 Last visit: 8/25/2022 Posts: 1750 Rating:
Dear Ammy, Here in this case, all led glows continuosly. It is not blinking continuosly so does it make any difference? Waiting for your feedback. |
VANDE MATARAM..... |
4/27/2012 12:08 PM | |
Joined: 4/24/2006 Last visit: 9/14/2023 Posts: 8592 Rating:
Hello, Please have a look at this manual: SIMATIC S7-300 CPU 31xC and CPU 31x: Installation See chapter 10.8.2 for more information about the LED's Best regards, Wizard |
4/27/2012 12:10 PM | |
Hello Amit_86, If All the LED is Glow then Try to power On/off the PLC & then See, also During Power off Remove the MMC & Put it Back... Normally upto now I have seen all the LED Flashing means CPU is faulty, But I have not Seen All LED Glows Continuosly..... may be this is new case... |
Ammy |
