8/9/2014 10:35 AM | |
Joined: 4/22/2010 Last visit: 12/13/2024 Posts: 5697 Rating: (715)
Hello, Since it is the direct successor (link)it should work without problem. But i would advice to hire someone with Siemens software at hand to help you on this. Replacing a CPU is a bit tricky without making a backup of the program. Regards, Marcjan |
Problem solved? |
8/25/2014 9:46 AM | |
Joined: 9/1/2005 Last visit: 1/13/2025 Posts: 4114 Rating: (195) |
new question published by engineer singh saabis split to a seperate thread with the subjectprice of all the cpu300. Best regards CS Moderator |
