10/4/2012 11:48 AM | |
Posts: 113 Rating: (0) |
I am using S7-300 Memory Card 6ES7952-1AM00-0AA0 ,if the battery is low the data will be there in this memeory card or not?
10/4/2012 12:46 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715) |
Hello, So you have an older CPU 300 with battery, right? See this FAQ: Which memory cards can you use with a S7-300 CPU? There are all cards for old and new types CPU. To keep your actual data you have to copy actual data to initial data, otherwise CPU restarts with wrong (initial) data after power return. Regards, Marcjan |
Problem solved? |
