6/22/2008 12:48 AM | |
Posts: 5822 Rating:
Hello, well actually Port Forwarding should work if you use all the required Ports, but it only works with one of the two HMI devices. What I would recommend for a working solution would be a VPN Network. With this type of network you may access all the Devices and you can do everything you want. Try this Application: WAN Access Methods and here especially the document: VPN Connections with standard DSL Routers (Gateway / Gateway and Gateway / Client) (English) But I personally expect, with my experience in Linksys Router,that the used type of Router does not support VPN Gateway capability. Youmay use other Routers. Best regards J_Bell |
6/24/2008 3:12 PM | |
Posts: 5822 Rating:
Hello, I hope it will work, usually it does. Cisco produces quite good stuff. Best regards J_Bell |
