9/12/2016 2:05 PM | |
Joined: 5/12/2006 Last visit: 9/22/2023 Posts: 21744 Rating:
Hello, first you should check why the PLC is in STOP Mode. Do you access the Slave during Startup and get a access error ? https://support.industry.siemens.com/cs/it/en/view/98278878
Christoph |
9/12/2016 2:50 PM | |
Posts: 4 Rating:
Thank you so much! creating an empty OB86 solved the problem. thank you again |
