4/20/2017 3:00 AM | |
Posts: 8 Rating:
i set the PG/PC interface from starter PC Adapter auto 1 as set in Step 7 but its online... |
4/20/2017 3:01 AM | |
Posts: 8 Rating:
accessible nodes of starter also not found any drive.. |
4/21/2017 11:29 PM | |
Posts: 8 Rating:
If you need to connect to both PLC and Drive then use a PROFIBUS connector with PG socket. Set Access point to S7ONLINE in PG/PC Interface. Hope this helps. but i am not using PG. i am using PC(laptop i5) which have only usb option. i send pic of mpi to usb adaptor which i using . pls find the attachment AttachmentPC-Adapter-USB-A2-Cable-for-Siemens-S7-200-300-400-PLC-DP-PPI-MPI-Profibus.jpg (61 Downloads) |
