11/25/2010 3:33 PM | |
Joined: 3/21/2006 Last visit: 3/19/2025 Posts: 10239 Rating:
Hello, Regards Intouch communication, the connection between external OPC Server and Intouch is done by using OPCLink. How to use look at Wonderware OPCLink User's Guide. And before you should assigned (established) connection between external OPC Server (in your case this is Kepware OPC) and controller (In your case S7-300 DP). More about this you could find (even here in this forum) at official site of Kepware. There have a manuals explaining how to connect (depends from the type of connection used there - MPI, Profibus, Ethernet) with S7-300. Hope this will helps. Best regards, Hristo Mihalev |
