2/10/2013 4:58 AM | |
Posts: 84 Rating: (1) |
Hi Follow steps byEastern, and apart from that you should install your hardware in proper way, Phisically on the rack not hard ware in siamtic manager, I cam across many errors once I had very simple error in installation, New rack shall be installed properly, check your wiring and bus fault and other things, sometimes error on new rack may cause fault on other racks. Good Luck. |
