8/16/2010 8:42 AM | |
Joined: 10/7/2005 Last visit: 4/18/2024 Posts: 3003 Rating: (1046)
Hello 256 I'm afraid to say that you may have to edit your STL code before you can display it inLAD and hope the FAQ below will help: Why can't you display an STL program in FBD or in LAD?
Assuming you get it all displayed in LAD, you can also print it all in LAD (see dchartier's advise on printing that he gave you in THIS thread). I hope this helps |
Cheers |
8/18/2010 3:58 PM | |
Joined: 9/27/2006 Last visit: 4/19/2024 Posts: 12256 Rating: (2664)
Hello Muhammad; Here are a few ressources that should help you to prepare for your conversion from STL. One is a instruction list cheatsheet for STL.(from plcdev.com). One is a sample conversion prepared by user RRobbins from plcs.net. Along with the support link proposed by fritz earlier, these should give you a good start. Good luck, much patience, and if you find any specific problems, please come back to us. Hope this helps, Daniel Chartier AttachmentS7 STL to Ladder sample[1].zip (105 Downloads) |
