10/21/2015 8:42 AM | |
Joined: 7/9/2015 Last visit: 9/20/2023 Posts: 3539 Rating:
Hi Peter,
I see that your PLC has a very old firmware. I would update to V2.6.10. Please look here: https://support.industry.siemens.com/cs/de/en/view/18722504
Not every CP is working fine with old CPU. You should check if your Hardware is compatible.
Regards, Towome |
If my post was useful, please rate me - thank you! |
10/21/2015 8:50 AM | |
hi Peter, the reason of this error is not easy to find. see this allready existing threads with the same error from last week. CPU 315-2DP, sometimes goes to STOP mode and turn on the SF ledI guess there is a internal problem whit the communication to a central IO-module, like backplane-bus-problem. How old is your CPU? Maybe a FW-Update could help? Does this error occur often? regards, |
10/22/2015 9:48 AM | |
Joined: 3/21/2006 Last visit: 7/12/2023 Posts: 10221 Rating:
Hello, You can attach here the diagnostic buffer message list. Which organization blocks do you need for error handling in STEP 7 V5.5? (the meaning of prevent CPU to go in STOP) Search for 'event 494D' to find a lot of discussions... Best regards, Hristo Mihalev |
