12/15/2005 12:24 PM | |
Posts: 25 Rating: (1) |
Friends, How can I configure S7-400 CPU 414-3DP as slave to FujiPLC on PROFIBUS network. Regards Demi |
12/15/2005 1:09 PM | |
Joined: 8/25/2005 Last visit: 10/5/2024 Posts: 1162 Rating: (111) |
Hello DEMI, I found the following FAQ which discripe exactly what you need I think: Connecting a S7-400 CPU to a external master as DP slave Best regards Sabine |
9/15/2009 5:11 PM | |
Joined: 10/9/2007 Last visit: 1/13/2025 Posts: 1253 Rating: (115) |
Dear colleagues I've followed the instructions for configuring a S7-400asDP Slaveconfiguration. https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=13091565&caller=view But BUS2F led on CPU is blinking and attached you can see the Diagnostic window in S7. It says it cannot find the address. But the master is connected (it is a WinCC, just for testing) and on Simatic Net diagnostics on Master side I can see the slave is present, with correct address. Any idea? Mike J |
Energy Automation products: Sicam, Siprotec, Digsi |
