1/30/2018 3:24 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello ABoskma Here is the official FAQ: https://support.industry.siemens.com/cs/ww/en/view/90528617 and here you can check if your hardware supports the Routing: https://support.industry.siemens.com/cs/ww/en/view/584459 Bye Murof |
1/30/2018 3:54 PM | |
Hello ABoskma The last thing i remember is a Chapter of S7 Routing in https://support.industry.siemens.com/cs/ww/de/view/73502293 do you use Classic Step7 Manager and TIA together or all in TIA Portal? Bye Murof |
1/31/2018 7:56 AM | |
Joined: 5/12/2006 Last visit: 3/21/2025 Posts: 22596 Rating:
one more FAQ for this special topic https://support.industry.siemens.com/cs/ww/en/view/109474569 |
1/31/2018 9:16 AM | |
Joined: 1/30/2018 Last visit: 11/15/2024 Posts: 6 Rating:
Tried firmware update because of the changes: 2. Product improvements
Also didn't work. Didn't select the correct subnet this morning I will try your suggested FAQ |
Last edited by: Jen_Moderator at: 1/31/2018 9:33:21 AMInserted right link. Last edited by: ABoskma at: 1/31/2018 3:49:32 PM |
1/31/2018 3:48 PM | |
I got it working! The firmware update helped solving my problem. |
