1/13/2009 3:44 AM | |
Posts: 23 Rating:
Hi all, I have a fault tolerant S7-400H system with two CPU 417-4H. I want to connect them via Ethernet to an engineering PC for service at the same time. May i use a Scalance X200 for this purpose? The diagram is described in the attached file. Please help me. Attachmentnetwork.pdf (113 Downloads) |
4/3/2015 12:26 PM | |
Posts: 12 Rating:
You can use without any problem. This is simple switch and nothing to worry about it. You can go ahead. Check and confirm |
