10/11/2012 9:58 PM | |
Joined: 9/27/2006 Last visit: 9/19/2024 Posts: 12282 Rating: (2684) |
Hello ta2mix; Ithink you have a few choices, depending on the input voltage availableand the output current required: SITOP PSU300S - The high-performance, standard power supply for 3-phase networks SITOP compact - Power Supply SITOP - Siemens SITOP smart - Power Supply SITOP - Siemens And for a view of all existing SITOP modules: the Sitop central webpage Hope this helps, Daniel Chartier Edit: Just in case I did not understand the full question. If you were asking also for a S7 CPU with ATEX certification and on-board AI, then: The following link will show you the ATEX certificates for the S7-300 Compact CPUs. http://support.automation.siemens.com/WW/view/en/33519671/134200 Since aS7-314C (or S7-314C-2DP, or S7-314C-2PTP) will have on board AI channels (4 AI) you could probably find them useful in your application. D.C. |
Last edited by: dchartier at: 10/12/2012 3:29 AMLast edited by: dchartier at: 10/11/2012 9:58 PM |
