12/15/2009 10:54 AM | |
Joined: 12/9/2009 Last visit: 4/18/2024 Posts: 156 Rating:
Hello I have found the following sample http://support.automation.siemens.com/WW/view/en/6709721 Maybe it helps you with configuration and programming. Good Luck |
12/15/2009 11:09 AM | |
Joined: 8/25/2005 Last visit: 3/21/2025 Posts: 1162 Rating:
Hello APAS, have you seen this example: DP interfacing IM 308-C (slave) and CP 315-2 (master) with STEP 7 V5.2 and COM PROFIBUS V5.1 Hope it will be helpful Best regards Sabine |
12/16/2009 4:58 AM | |
Posts: 10 Rating:
Hi Hulzhex and Little Homes Thanks for your reply. It works now after we put a pair of DI and DO Universal Module in. Your support is so much appreciated. Keep it up all. Best regards, Dan |
