6/17/2011 6:56 AM | |
Posts: 8 Rating:
Can any body help me to understand the pointer concept in s7 programming..how can i link any udt throug pointer... |
6/17/2011 9:00 AM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
How can you calculate an offset for an ANY pointer or change the pointer? How do you parameterize blocks, which have "ANY"-type or "Pointer" type parameters? |
6/17/2011 11:17 AM | |
Joined: 1/28/2009 Last visit: 6/8/2023 Posts: 6805 Rating:
Hi Also check the following attachment extracted from the STEP7 online manual. Also check chapter 25 of the following book: http://www.publicis-books.de/cms/website.php?id=/en/produkte/automatisierungstechnik.htm&action=detail&pid=29859 Also check the avaiable source codes here: Automating with STEP 7 in STL and SCL README.TXT PDF Programming Examples "SCL-Book" ZIP Programming Examples "STL-Book" ZIP regards AttachmentPointer.zip (34 Downloads) |
6/17/2011 11:34 AM | |
Posts: 8 Rating:
Thanks to all |
