10/22/2007 9:13 PM | |
Posts: 33 Rating:
Where I can found the Reference to discribe functions in S7 Stansard Library? specially I am looking for S5-S7 converting Blocks Like FC81/82/83/84. |
10/23/2007 8:48 AM | |
Joined: 9/27/2006 Last visit: 6/7/2023 Posts: 12036 Rating:
Hello ralphtang; There is information on S5-S7 converting blocks in the S5S7_e.pdf manual (accompanies the S5 to S7 converter software; it should be installed in your Simatic-->Documentatiojn folder, when you install Step 7; alternatively, it is downloadable from Siemens' support website). There is also an entry in the FAQs on Step 7 software that lists and describes the S5-S7 conversion blocks: http://support.automation.siemens.com/WW/view/en/14529143 Finally, the online help of Step 7 should give you detailed info on each available block from its libraries. Hope this helps, Daniel Chartier |
