11/22/2018 9:10 AM | |
Joined: 8/3/2009 Last visit: 3/14/2025 Posts: 14990 Rating:
Hello KhanhLee you can do this in 3 steps: look in the manual of the Panel: https://support.industry.siemens.com/cs/de/en/view/90114350 - First Step Page 54 - Second Step change the IP Adress of the Panel also to the new Range - Third Step Page 55 -> With this two steps the Communication of the Panel to the PLC should work also after the Change. Bye Murof |
