7/13/2016 3:52 PM | |
Posts: 21 Rating:
Hi tlerdrden ! First, where do you gonna install the OPC server? Then from the programming of the PLC (That CPU with TIA Portal) You have to configure the connection to that OPC server from Devices & Networks. Here is the Manual of S7-1200 Programmable controller if you need it. Best Regards! |
