6/22/2009 11:58 AM | |
Posts: 45 Rating:
I have the same registry entries and all works fine. Maybe you use wrong COM object name when connecting to S7ProSim. Here's the manual from SIEMENS (if you have not seen it before) in attachment. I used quite different COM object name from non-basic applications - "S7wspsmx.S7ProSim.1" Attachments7wspscb.pdf (338 Downloads) |
6/23/2009 9:02 PM | |
Posts: 45 Rating:
I will try with V5.4 SP3 shortly Best regards |
6/23/2009 9:32 PM | |
Posts: 45 Rating:
try OLE/COM Object Viewer utility, a good thing Within this utility I found S7ProSim object in Object Classes->Grouped by Component Category->Automation Objects->S7ProSim Class Best regards Attachmentoleview.zip (338 Downloads) |
