2/20/2017 3:59 PM | |
Joined: 3/2/2007 Last visit: 3/24/2023 Posts: 827 Rating:
how can we order many Siemens key operated switches, but with one same key to actuate all of them? what will be the order numbers? thank you 3SU1050-5PF01-0AA0 , BKS KEY-OPERATED SWITCH, 22MM, ROUND, METAL, SHINY, LOCK NO. S1, WITH 2 KEYS, 2 SWITCH POSITIONS O-I, LATCHING, ACTUATING ANGLE 90 DEG., 10:30H/13:30H, KEY REMOVAL POS. O
... thank you ... |
2/21/2017 9:18 AM | |
Posts: 17 Rating:
https://mall.industry.siemens.com/mall/en/tr/Catalog/Products/8220214 |
2/21/2017 9:20 AM | |
can we order a Master-pass key? as mentioned in the below links. what will be the order number for our below switches? thank you https://mall.industry.siemens.com/mall/en/tr/Catalog/Products/8220214 http://cmsapps.sea.siemens.com/controls/icc2010/10IndControl_%20pdfs/10IC_10/10_064.pdf 3SU1050-5PF01-0AA0, BKS KEY-OPERATED SWITCH, 22MM, ROUND, METAL, SHINY, LOCK NO. S1, WITH 2 KEYS, 2 SWITCH POSITIONS O-I, LATCHING, ACTUATING ANGLE 90 DEG., 10:30H/13:30H, KEY REMOVAL POS. O |
... thank you ... |
2/21/2017 9:25 AM | |
Joined: 5/17/2010 Last visit: 3/9/2023 Posts: 213 Rating:
Hi there, When you order 3SU1050-5PF01-0AA0 you will get a key-operated switch with lock type BKS, S1. The key of this switch also fits to all other key-operated switches with lock type BKS, S1. If you purchase for example 5pcs 3SU1050-5PF01-0AA0 you can operate all of these switches with the same key. Further for BKS, CES and IKON key systems it is possible to realise master and master-pass key systems. For details see catalog IC10 2017 page 13/81 (chapter 13). Catalog IC10 download at: www.siemens.com/sirius/catalogs Best Regards Michael |
2/23/2017 10:32 AM | |
thank you all for your help. one last question: can we modify the following switch to have the Key Removal in both positions (on and off) ? 3SU1050-5PF01-0AA0, BKS KEY-OPERATED SWITCH, 22MM, ROUND, METAL, SHINY, LOCK NO. S1, WITH 2 KEYS, 2 SWITCH POSITIONS O-I, LATCHING, ACTUATING ANGLE 90 DEG., 10:30H/13:30H, KEY REMOVAL POS. O |
... thank you ... |
