4/18/2016 8:14 AM | |
Joined: 5/11/2010 Last visit: 12/5/2022 Posts: 89 Rating:
Hello friend, I think you are using MW. use DBW and enable the retain check box. |
4/18/2016 11:13 AM | |
Joined: 4/28/2015 Last visit: 2/3/2023 Posts: 9027 Rating:
Hello Marek, prepared 2 pictures how to define DB block to save your INT value. On Picture 1 steps show sequence for creating global DB block. Point 3. show selection of access to block, you can select as you require to retain your data. On Picture 2 steps show how to define your INT Variable and how you can set it as Retain. Pls after this sequence compile your DB block to make changes ok. Hope this helps you. Update: pls check again Kahl's and William's usefull additions. AttachmentDB.zip (109 Downloads) |
Last edited by: Duris_I at: 4/18/2016 11:15:46 AMLast edited by: Duris_I at: 4/18/2016 11:16:34 AMWith best regards... |
4/18/2016 12:15 PM | |
Posts: 99 Rating:
Thanks all and your picture was great :) Have nice day Marek :) |
