2/9/2018 3:54 PM | |
Posts: 8946 Rating: (999) |
You can't deselect "override user" in transfer - setting window? |
2/9/2018 3:59 PM | |
Joined: 10/18/2012 Last visit: 11/22/2024 Posts: 225 Rating: (23) |
Hi dabopa, when you update your runtime project on your IPC477D, then you overwrite all users that may exist on the runtime project of your IPC. To avoid loosing the users every time you update the runtime project, you may either create the users in your engineering project, or you may export the existing users of your runtime project and import them after the update again. More details about this topic can be found in the WinCC Professional V13 manual at You may also consider to look at the specialized forum talk for WinCC (TIA Portal) at https://support.industry.siemens.com/tf/ww/en/threads/261/?page=0&pageSize=10. regards, |
