1/26/2015 10:43 AM | |
Posts: 1299 Rating:
Hello, it depends on the project needs which runtime system you should choose. just control and store "some" process data sounds as if you can also use runtime advanced instead of professional. here you can find technical data: https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=63974837515&Language=en-US&TopicId=59067186059 K!ke |
