7/11/2014 8:38 AM | |
Posts: 1368 Rating:
Hello, mh..that´s really strange, Do you use MRP as redundancy mode? Do you configure " Forward Time" and "Automatic" in the CP Settings? |
7/17/2014 1:53 PM | |
Joined: 2/2/2007 Last visit: 4/8/2024 Posts: 55 Rating:
The time is set to 10 min. And I' m monitoring SCALANCES much longer. No sybchronisation. |
7/17/2014 2:07 PM | |
Posts: 1368 Rating:
Hello, the Failsafe communication has no influence on the time sync. Do you use the actual FW of the SCALANCEs? Here it is http://support.automation.siemens.com/WW/view/de/82142251 Do you use TIA or STEP 7 V5.5? |
7/17/2014 2:40 PM | |
Thank you, I will. Best Regrds |
7/17/2014 3:25 PM | |
I have Step7 V5.5. The FW is 4.5.1 on some and 5.0.1 on the rest. |
