7/11/2014 4:26 PM | |
Posts: 2 Rating:
ThanksPittiplatsch, I copied configuration to C Plug through the web interface already. And as i mentioned this issue is random. Also I observed that the communication break with clients is only in those which are shifting from one access point to another. It is a rapid roaming configuration. I have also tried with different roaming thresholds.
7/14/2014 9:12 AM | |
Posts: 1368 Rating:
Hello, before all: Do you use the actual Firmware? http://support.automation.siemens.com/WW/view/en/89849822 |
