10/24/2007 4:20 PM | |
Posts: 5822 Rating:
Dear Micael, did you set the Device-Name of the PROFINET IO Device to the SCALANCE X? If you are not sure try to check this in your PC, if it is connected to Ethernet, what you said, this should work. Check this Manual for more details: PROFINET IO - Configuration & Diagnostics Best regards J_Bell |
