3/16/2018 5:38 AM | |
Joined: 12/23/2009 Last visit: 1/11/2023 Posts: 9 Rating:
Hello, "SCL Blocks uploaded from an S7-300/400 module cannot be edited" I think, the TIA version is not compatible so I tried uploading with different versions. Result: The Version Step7 V5.5 and Step7 V13 can not be uploaded. The Version Step7 Pro V13 SP1 Update 0 and Step7 Pro V13 SP1 Update 9 fully uploaded but still the same error on. I don't have source program If you know how to open it, please help Thanks.. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 3/16/2018 12:51:58 PMNew subject after splitting |
3/22/2018 6:59 PM | |
Joined: 4/3/2017 Last visit: 9/20/2022 Posts: 37 Rating:
It's a longshot, but can you generate source from block then import it back into your program? Cheers |
2/3/2019 10:12 PM | |
Posts: 11 Rating:
Did you solve? I have the same problem... |
2/4/2019 8:24 PM | |
Joined: 6/14/2015 Last visit: 3/23/2023 Posts: 190 Rating:
no.I have this problem yet. |
2/5/2019 8:59 PM | |
Joined: 4/23/2018 Last visit: 9/19/2022 Posts: 1 Rating:
Same problem here :( |
