12/4/2009 12:31 AM | |
Joined: 4/19/2008 Last visit: 6/25/2024 Posts: 1525 Rating:
Hi Tomy. Please Find the SCL demonstration may be it will help you to solve you problem http://support.automation.siemens.com/WW/view/en/21062480 if you compile the SCL Source file it will egneratee the respective block in Step 7. |
Ammy |
12/4/2009 7:44 PM | |
Joined: 5/4/2009 Last visit: 5/28/2024 Posts: 914 Rating:
OK.. So please, provide me with simple example in SCL, please Your friend. Tomy. |
Aim Higher |
12/4/2009 7:58 PM | |
Hi Tomy, Please find the Manual in which you will find the example also. with step by step instruction. is it ok............... AttachmentProgramming in high-level languages with S7-SCL.pdf (269 Downloads) |
