5/14/2014 3:12 PM | |
Joined: 7/7/2010 Last visit: 12/9/2023 Posts: 13994 Rating:
Have you reported this *bug* via Support Request? I too have run into SCL programming problems and the slow-downs and system crashes that result from live SCL programming within the build-in SCL editor in TIA portal - all versions supporting scl on the s7-1200. I found certain triggers that no matter what result in crashes and would report those. An update or patch or new version later and that specific trigger would not necessarily crash portal, but it would still cause odd behavior once I moved beyond that trigger. At that point, I would save, exit portal, and start fresh and hope my project did not become corrupted. Good luck to you in figuring out the undo. I find it useless in SCL, and not possible while online. |
science guy |
