5/8/2015 8:05 AM | |
Joined: 12/13/2013 Last visit: 5/9/2023 Posts: 36 Rating:
Sir, I am using Simatic TP1500 Basic with S7300 PLC. Need to change the screen from PLC. Is it possible? Regards Rohit Jage |
5/8/2015 8:50 AM | |
Joined: 4/24/2006 Last visit: 9/29/2023 Posts: 8593 Rating:
Hello Rohit J, Yes, it is possible. I found the following links (They are about WinCC flexible, but it is the same using WinCC TIA Portal) how do you configure a screen change via the controller in WinCC flexible? Best regards, Wizard |
5/8/2015 8:55 AM | |
thanks for the reply. but the given links are showing error. Rohit
5/8/2015 8:59 AM | |
Hello, You search for Id.nr.: 98105706 and 24372078
