5/26/2010 9:00 AM | |
Joined: 5/28/2008 Last visit: 12/8/2015 Posts: 901 Rating:
Hello PPND, you only have to take your script to the required tag. You have to tie the script to tag --> Event --> Change value. Then the script is triggered by changing value of the tag. But this is not possible with internal tags! In this case you could use Analog Alarms. regards Manfred |
5/26/2010 9:24 AM | |
In this case you could use Analog Alarms. |
