7/25/2006 12:51 PM | |
Posts: 1084 Rating:
Hi, Please read thisThread. Several ideas are being discussed for the same problem as yours. The solution to this problem was the server action / global action, but you have set ik oke. But when you read it you can use the ideas to find out in which part your problem resides. with regards, Ikkezelf |
7/31/2006 12:31 PM | |
Posts: 102 Rating:
Hi I do not have this problem when my triger tag is an internal tag. Thanks, Mehrnoosh |
